KZ750 Spectre CYLINDER HEAD TROUBLES
  • bbqbrandon
  • bbqbrandon's Avatar Topic Author
13 Jan 2015 21:32 - 13 Jan 2015 21:32
#658639
Hey KZriders,
New here and new to bikes and could use some help. I have a 1983 KZ750 Spectre I'm building up right now. After taking my cylinder head to the machine shop to get some stuck buckets off, I found out that most of the cam screws (13/15 or something like that) were also broken inside. So with both stuck caps (trust me we tried everything and still 4/8 wont come off!) and $250 dollars of screws to drill out I figured that cylinder head isn't worth it anymore so I'm looking to get a new one as used range from $100-200 on ebay. As Spectres are relatively rare I was wondering; if other KZ750 models have compatible cylinder heads?
Would very much appreciate the help, I've tried Google and Wiki and the whole sorts with no luck.
Thanks! :)
- Brandon
Last edit: 13 Jan 2015 21:32 by bbqbrandon.
  • baldy110
  • baldy110's Avatar
Re: KZ750 Spectre CYLINDER HEAD TROUBLES
14 Jan 2015 08:57
#658667
Any four cylinder KZ750 head will work.
The following user(s) said Thank You: bbqbrandon
  • bbqbrandon
14 Jan 2015 15:45
#658709
Thanks bae,
you just saved a lot of time and a little bit of cash. Much appreciated.
  • Nessism
  • Nessism's Avatar
14 Jan 2015 18:18 - 14 Jan 2015 18:20
#658730
If you haven't bought a new head yet I've got one you might be interested in. It's from a 1980 or 1981 KZ750E.
[IMG
Last edit: 14 Jan 2015 18:20 by Nessism.
  • bbqbrandon
14 Jan 2015 18:40
#658731
PM'd
