piston rings
- kawi810
piston rings
09 Jan 2015 20:21
i am putting together another GPZ 750i need a set of stock RINGS bore size (66 mm)every where i look they are about $25.00 a set .is this about right? is there aftermarket rings available?or is KAWASAKI the only manufacture of piston rings for this bore?
original owner of a 1984 gpz 750
1985 turbo 750 stock, being restored.
1984 gpz 750 with 810 cc wiesco's megacycle cams(471-10) 34 mm flatslides v&h pipe ported head dyna ignition. bottom end, crank case from turbo 750 and sprockets.
- Mcdroid
- Gone Kwackers
Re: piston rings
10 Jan 2015 08:16
I recently purchased OEM/NOS sets of standard rings for my GPz750 and your price of $25/set is better than what I paid ($32/set). I am unaware of any aftermarket standard rings but you might be able to get Hastings manufacturing to craft some for the 750 if you have all the dimensions.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- kawi810
Re: piston rings
10 Jan 2015 08:41
i just started looking and you are right $35.00 to $40.00 a set.i think i paid about $25.00 for my wisecos.
Re: piston rings
10 Jan 2015 16:58
I've got a KZ750E and rings cost $50/piston. You got it good.
