1976 kz900 cylinder o rings have or no?
  • 123vucku
  • 123vucku's Avatar Topic Author
09 Jan 2015 05:43
#658143
Does a 1976 kz900 a4 have cylinder o rings that go over the 4 outer studs ? Mine when I took it off didn't have them wondering if it needs them . Had a head gasket leak .
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: 1976 kz900 cylinder o rings have or no?
09 Jan 2015 06:02
#658149
No they don't. A common cause of leaks in this area is when it is cleaned scratches leed to the out side. If there are scratches or if you are sanding to clean, do it in a circular pattern around the oil galleys or combustion chambers. It is harder for oil or gas to pass by them. Use fine paper and be sure the surface is perfectly flat.
  • 123vucku
09 Jan 2015 12:25
#658188
Thanks for the help also would applying a small bead of sealant be effective also or is this not such a good idea
  • SWest
  • SWest's Avatar
  • 10 22 2014
09 Jan 2015 16:22
#658196
For a new gasket, a CLEAN surface should need no sealant. If there is damage in that area, I use the high temp. copper silicon. It can weep after a while but not gush. Do not use Permatex. Others use three bond or Yama bond.
  • 123vucku
09 Jan 2015 16:53
#658200
Why not permatex
  • SWest
  • SWest's Avatar
  • 10 22 2014
09 Jan 2015 21:18
#658224
You haven't tried to get that crap off? It's murder.
  • bluezbike
  • bluezbike's Avatar
09 Jan 2015 22:53
#658231
Although there are no O-rings around the four outer studs , make sure there are the two alignment pins on the front outer two cylinder studs. Along with doing what they are named (aligning) they also form a sort of oil seal for the front of the motor.......make sure they are not clogged in any way as that (and the two rear studs) is where the oil travels through to get to the head, valves and cams. :)
79 KZ 1000 LTD
  • SWest
  • SWest's Avatar
  • 10 22 2014
10 Jan 2015 05:30 - 10 Jan 2015 05:35
#658243
Yes and you will notice the copper rings around the oil journals, that surface must be clean and even to seal. The rubber large O ring that goes around the cam chain galley must be new, It has a nasty habit of drying out and cracking. I use the one piece early style head gasket because of this.
Last edit: 10 Jan 2015 05:35 by SWest. Reason: add text
  • 123vucku
10 Jan 2015 08:08
#658261
Yea I've ordered one o four those mine was pretty dried out thanks for the help
  • SWest
  • SWest's Avatar
  • 10 22 2014
10 Jan 2015 13:25
#658308
The aftermarket ones don't last. I had to reuse my Kawasaki one when I had a problem. I ordered the one piece gasket and never will use a two piece again.
