KZ1100 Aftermarket Head
- jeffw
06 Jan 2015 08:31
I recently purchased a 1982 KZ1100-A2 and I was told by the PO that is had some type of race head, but I can't find any special marking on it besides 2-2 on top of it. Any insight on how to determine if it is or if he was talking out of his butt :laugh: .
1977 KZ650 B1 "Cafed"
4-1 & Pods, Electronic Ig. & Dyna Coils
forums.kz650.info/index.php?topic=9020.0 - SOLD
1982 KZ1100 A2 Stripper
kzrider.com/forum/11-projects/596850-198...100-a2-shaft-project
- pete greek1
Re: KZ1100 Aftermarket Head
06 Jan 2015 09:06
Any Head can be called a Race head, if it has been modified from stock specs, with porting , oversized valves heavy duty springs, race Cams, ETC, ETC,
Pete
Pete
- Tyrell Corp
06 Jan 2015 10:08
In used bikes , a ''worked' head could be anything from a skim or cleaning up the ports with a dremmel, right up to full race spec. It is one of those areas that people often bullshit about, particularly if the work was not done by them. Fitting a later gpz head with bigger valves and hotter cams is also possible.
(Yoshimura used to do exchange stage 3 heads: gas flowed, ported and big valves, titanium collets and race springs. The 596cc were making 1000cc superbike F1 qualifying times.)
- jeffw
06 Jan 2015 12:13
He had a specific company name, can't remember now. Was there specific heads made by other companies for this bike? Also what does the stock head for markings have?
- spdygon
06 Jan 2015 15:43 - 06 Jan 2015 15:46
all original heads are sent to 2nd or 3rd party companies to do the work.depending on what you need...is what was done.
as far as # on heads i do not know ..dont think the engine cases , block , heads have the same #. and i dont have an engine paart either to see.
my brother would port his own heads......his friend had a machine to cut the seat and valve , etc.
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
1974 Z1 900 project
Last edit: 06 Jan 2015 15:46 by spdygon.
- gearheadmm
- MUCH MORE BOOST..........I mean BRAVO
06 Jan 2015 20:11 - 06 Jan 2015 20:18
Searched a little bit
I know someone used to make new heads
They are noticeably thicker.
For your fuel bike!
In trouble for posting??????
Someone posted this here a while back.
www.racecase.us/aluminum_billet_blocks.htm
For your fuel bike!
General Joeseph Dunford FOR PRESIDENT!!!
69.46.28.106/forum/11-projects/413221-80-kz-1000-st-recycled
Last edit: 06 Jan 2015 20:18 by gearheadmm.
06 Jan 2015 20:20 - 06 Jan 2015 20:21
By any chance does it use 8 spark plugs? Maybe it has been dual plugged by kzzone (APE). Ed
Last edit: 06 Jan 2015 20:21 by 650ed.
- zed1015
07 Jan 2015 00:24gearheadmm wrote: Searched a little bit
For your fuel bike!
VOREX made heads for the KZ .
They were mainly for the serious top fuel drag racer etc.
They were taller and won't fit in to a stock KZ frame without hitting the top tubes.
They have massive ports and valves and the finning is shallow and chunky much like APE/WISECO big blocks etc.
They could never be confused with a modified stock head.
Posting a pic would identify one instantly.
07 Jan 2015 05:35
- jeffw
07 Jan 2015 06:52
I guess I won't know unless I tear into it but no plans to due to excellent leak down numbers I got.
- zed1015
07 Jan 2015 09:13If you have to ask you can't afford it :laugh:
- zed1015
07 Jan 2015 09:16
If it's in a stock framed road bike it won't be a Vortex.
Most likely you have a ported head by one of the well known tuners if the PO quoted the name as a selling point.
