Oil Level Sight Glass Replacement
  • ramtough_63
  • ramtough_63's Avatar Topic Author
03 Jan 2015 14:23
#657678
is it as straight forward as it seems to replace the sight glass? Or is it a major pain or a
trick that should know about?
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • Mk.2
  • Mk.2's Avatar
Re: Oil Level Sight Glass Replacement
03 Jan 2015 14:52
#657687
Just popped mine out 30 min ago, no big deal. I heated up the area with heat gun then used seal puller to pry up on the inside one of the little holes in the metal piece on the back of the sight glass and it came out easy.
the bore for the SG is straight thru and doesn't have a shoulder or counter bore on the ID for the seal to seat against so when I re install I'll go from the inside/out reverse of removal, it's my first so I can't say which was is right or if it's irrelevant.
Matt
KZ1000A1--current project
KZ1000A3A
Phoenix
The following user(s) said Thank You: ramtough_63
  • SWest
  • SWest's Avatar
  • 10 22 2014
03 Jan 2015 15:24
#657693
I hate mine. It almost cost me a motor once. What's wrong with the old fashion dip stick? I cleaned mine with carb cleaner and a Q tip in my screw gun. I let it soak, then ran the tip in there. Took a few tries. I had to bend two of the holes out a tad to get to it but now it works fine. I still hate it.
  • kaw-a-holic
  • kaw-a-holic's Avatar
03 Jan 2015 15:42
#657698
I've done 2 and both are simple. The pic in Phoenix Fighter build has a brand new one it. Pop the old one out and gently push the new one in from the inside out like MK2 stated. Was a bit skeptical the first tiem I did one, I always expected it to leak, never did. I purchased mine from Z1 of course.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
  • ramtough_63
03 Jan 2015 17:07
#657704
Thanks guys. I have always left it in to pollish but was thinking of sending out for chrome and installing a new one
Glad to hear its not a major stand on your head tedious experience
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
