KZ 650 head on KZ 750 barrels? both 1980 engines
  • Bovine
  • Bovine's Avatar Topic Author
02 Jan 2015 15:44
#657604
Okay just trying to use my exsisiting parts up. Will a 650 head work on a 750's barrels? Both engines are 1980's...
The 750 head is damaged ( broken studs and tach drive boss ) it came from a wreck I bought. The 750 engine was covered in oil and the compresion is low on cylinders # 1 & # 2..... I have a 650 head.. But I'm sure it needs valve job.
Will it be worth rebuilding the head? Or should pop for a e-bay 750 head ? I'd rather not do the pig in a poke with the e-bay head.....
  • zukdave
  • zukdave's Avatar
Re: KZ 650 head on KZ 750 barrels? both 1980 engines
02 Jan 2015 16:31 - 02 Jan 2015 16:34
#657614
As long as their both HYVO cam chain the 650 head is a bolt on swap. It has a slighty smaller
comp.chamber and will bump compression maybe a 1/2 point
but no biggie.
Port's are just a little smaller and with the 750 cam's should make
good mid. range power.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
Last edit: 02 Jan 2015 16:34 by zukdave.
The following user(s) said Thank You: Bovine
  • Nebr_Rex
  • Nebr_Rex's Avatar
02 Jan 2015 16:47
#657619
Why is compression low on 1&2?
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • Bovine
02 Jan 2015 17:15
#657624
I'm guessing a blown head gasket... It ran after some tinkering clean plugs..and a some head pipes..carbs drained etc. She hissed at me a lot! Cylinders # 3 & # 4 had about #120 psi, # 2 & # 3 were about the same, # 20- # 30 psi... Guessing the head gasket is blown between 1&2... ? Once the head pipes were off you could see the exhaust valves on those two cylinders look like they are torched. The carb mainfolds were all gooped up with silicone as well.
The right side of the head took a bad hit. Frame colasped into the head. Broke off tach drive boss, and exhaust studs... head pipes crushed, most of the front end was destroyed. I'm going to load the engine up and take it to the car wash... Bike has some haunting karma about it.. Anyway....Hoping to salvage the 750 lower end and bolt up parts from my pile!
