Engine Number Information
  • lhemrick
  • lhemrick's Avatar Topic Author
19 Dec 2014 05:18 - 19 Dec 2014 05:36
#656400
Where can I go to run a set of engine numbers to make sure they are what I was told they were. The bike and or engines are supposed to be 81 KZ750 LTD's.
Thanks!
Last edit: 19 Dec 2014 05:36 by lhemrick.
  • martin_csr
  • martin_csr's Avatar
Re: Engine Number Information
19 Dec 2014 05:25
#656401
CycleChaos.com has engine & frame number info for many Kawasaki motorcycles.
Zedder.com is another place to try.
  • davido
  • davido's Avatar
19 Dec 2014 05:32
#656402
Z Power helped me.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
19 Dec 2014 07:15
#656415
Also Z1 Enterprises, such as:
Click here > www.z1enterprises.com/ShopByCategory.asp...&category=0101010304
Good Fortune! :)
  • SWest
  • SWest's Avatar
  • 10 22 2014
19 Dec 2014 08:54
#656420
Just wondering, is there a reason you need to check out the numbers? In California the numbers are on the title and registration.
  • lhemrick
19 Dec 2014 10:26
#656423
I'm a honda guy but own a couple of KZ's one being this 750. It needs an engine rebuild and when it comes to piston rings I'm being told even among 750's and the LTDs they are different. I have purchased a donor engine for some parts I need and just want to make sure it also is a 81 750 LTD engine.
  • SWest
  • SWest's Avatar
  • 10 22 2014
19 Dec 2014 10:41
#656424
You might try z1enterprizes to see if there are any differences. I don't think so unless someone changed the pistons.
I'd make sure before I ordered. It happens on used bikes. Good luck.
