1980 KZ550A worth fixing?
- Mark Ohio 1976
- Djckay
Re: 1980 KZ550A worth fixing?
10 Dec 2014 15:04
Manual cam chain tensioner installed. I turned the engine till the chain went loose and tightened the tensioner down till there was about 1/4" play up or down. Put it back together and MOST of my problems went away. Now Im back where I was a week ago. Starts fine, idles fine, but when revved up past 3500 rpm it is not letting up unless it is shut off. From what Ive read, I would suspect the vacuum hose and vacuum switch?
1980 KZ550A
- loudhvx
10 Dec 2014 19:51 - 10 Dec 2014 19:53
Are you installing the valve cover after the chain is tensioned?
If you haven't seen it yet, this page explains why you should not do that. It also has better drawings for timing the cams:
home.comcast.net/~loudgpz/GPZweb/CamsKZZ...KZZXZR550500400.html
Your symptoms, now, do sound like vacuum. That should be easy to check using carb cleaner etc.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 10 Dec 2014 19:53 by loudhvx.
