Install the Oil pan gasket dry?
  • Nessism
  • Nessism's Avatar
  • Away
Re: Install the Oil pan gasket dry?
05 Dec 2014 15:35 - 05 Dec 2014 15:38
#655437
swest wrote: Kawasaki bond, Yama bond and the like is great for the case halves, silicon is not. It can be used to fill small voids as long as a good gasket follows. JMO.
Interesting comment. Kawasaki specifies Threebond (or Kawabond as it were) 1207B for case halfs, which is a silicone material. Rebuilding my 750 engine and removing the oozed out black sealer material confirmed that Kawasaki uses silicone. Threebond also sells non-silicone case sealer materials which are a good substitute, but both Kawasaki and Suzuki spec the 1207B stuff on a lot of engines (maybe because it's black).
Last edit: 05 Dec 2014 15:38 by Nessism.
  • LarryC
  • LarryC's Avatar
05 Dec 2014 20:18 - 05 Dec 2014 20:21
#655457
Larry C.
Last edit: 05 Dec 2014 20:21 by LarryC.
  • LarryC
  • LarryC's Avatar
05 Dec 2014 20:25
#655459
Larry C.
