dynatek plug wire length
  • Cal
  • Cal's Avatar Topic Author
29 Nov 2014 03:28
#654895
Greetings KZ lovers,has anyone installed the dyna s ignition,coils and plug wires on their LTD1000 ?? If so,,im curious as to what length you cut the plug wires,thanks very much,ride safe,vehicle drivers dont see you
  • Tyrell Corp
  • Tyrell Corp's Avatar
Re: dynatek plug wire length
29 Nov 2014 17:47
#654941
I think I know what you might be thinking here: short leads= lower resistance= bigger spark=better performance...correct!
In reality, if good leads, the resistance is only a few hundred Ohms per wire and makes little difference.
I like to get the 2-3 and 1-4 the same length with just a little slack in them.
