Kz 1000 rebuild
- keenan-n-cali
Kz 1000 rebuild
26 Nov 2014 15:22
I'm trying to rebuild an engine that sat outside for 7 years, the rings were frozen to the bores, but the cylinders look good now that I got them moving. So my question is do I replace the rings or bore it out with new pistons. Also should I replace the timing chain????? And where can I get the rings and new chain rollers???? This is my first time building a motorcycle engine, any advice would be helpful, THANKS
Re: Kz 1000 rebuild
26 Nov 2014 15:48
Are the bores stained where the rings sat? You might be looking at a overbore. Any pics? If the cylinder walls aren't pitted you might get away with cross hatch hone and new rings. Z1 enterprises is a good source for parts. There are others. eBay is also a good place but be careful. SHARKS.
Post some pics so others can give advice as well.
The following user(s) said Thank You: PLUMMEN, keenan-n-cali
- LarryC
Re: Kz 1000 rebuild
26 Nov 2014 16:56
Can't make good chicken soup from chicken poop.....ingredients are everything :side:
Larry C.
Re: Kz 1000 rebuild
26 Nov 2014 17:00
YUP
- keenan-n-cali
Re: Kz 1000 rebuild
09 Jul 2016 19:38
I'm having trouble identifying these carbs, Can someone held me please.
Re: Kz 1000 rebuild
09 Jul 2016 20:03
Looks like VM 26's. Does it have a cap on the bottom? Could be 29's.
- keenan-n-cali
Re: Kz 1000 rebuild
10 Jul 2016 06:30
Picture of bottom , also found these carbs in a box of parts,does anyone know anything about them?
Re: Kz 1000 rebuild
10 Jul 2016 07:07
No pics?
