current value
- kzinksky
current value
23 Nov 2014 12:59
what's the difference between a kzp 1000 (J) engine and an 1100 specter engine? DL and, whats the value of 1980-1-2
1100? Turns over, no carbs, needs faring work.. DL
- PLUMMEN
Re: current value
23 Nov 2014 13:13
From what I remember the spectre engines were painted gold,other than that Im guessing theyre the same as j-motor.
$500-800 I suppose,depends on how bad somebody wants it.
- KZ Rat
Re: current value
23 Nov 2014 15:15
Remember the Spectre as a shaft drive- not a chain-that could be a problem depending on what you're doing.
1979 ltd 1260 1980 ltd 1075 2005 450x for the desert
- PLUMMEN
Re: current value
23 Nov 2014 16:29
I road an 1100 spectre back in the early/mid 80s when then were new,I was thinking about the top end being the same forgot about the shaft drive! :laugh:
