Mono conversion
  • kzinksky
  • kzinksky's Avatar Topic Author
Mono conversion
23 Nov 2014 11:26
#654458
I have a perfect 92 KZP, new engine, plenty of power, changed front drive spr. to a 16t, the rear to 37t. Cruises nicely @ 70mph @ 32-3400 rpm. Opened stock pipes, then gas trapped at rear, upped carb jets, indv. kn filters, etc.
I will change rear to monoshock. Researching..,, what modern rear mono swing will be the best swap. Need @ 3-4 more inches longer, have shop, can weld, machine, press, etc. Rear end first then front triple swap. Thanks for any help. Dave L. [email protected]
  • TexasKZ
  • TexasKZ's Avatar
Re: Mono conversion
24 Nov 2014 05:09
#654492
Welcome, Dave. A couple of members here have made that conversion. You may way to check those threads. When I put mono shock in the search box, I got 154 hits.
