A CB900 Starter on a KZ1000 stud location
  • tomsbadkz
  • tomsbadkz's Avatar Topic Author
21 Nov 2014 08:21
#654298
when installing a cb900 starter on the kz1000, can the housing of the starter be rotated to relocate the battery post or do you only have the option to alter the clutch cover for fitment?
1977 kz1327
Cavanaugh Head 38.6/33
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
Re: A CB900 Starter on a KZ1000 stud location
21 Nov 2014 12:24
#654325
Yes, you can rotate the outer housing of the starter. Here's some info from MFolks on the subject. Ed
www.kzrider.com/forum/4-electrical/59407...ically-gifted#633341
  • baldy110
  • baldy110's Avatar
21 Nov 2014 12:25 - 21 Nov 2014 12:25
#654327
Yes it can that is what I did, I didn't want to modify my housing.
Last edit: 21 Nov 2014 12:25 by baldy110.
  • tomsbadkz
21 Nov 2014 13:09
#654330
thanks guys. I read that thread and sounds good. I bought the cb900 starter for $17.99 plus shipping. bench tested and it sounds and ran great. I have a 1327 with 10.5 to 1 motor that im building. its just been a slow process.
1977 kz1327
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
