Oil drain plug KZ650 - size of washer/o-ring?
- Piilgard
11 Nov 2014 13:52
Hello,
Can anyone tell me, as I don't have the possibility to unscrew and empty the oil atm, the size of the O-ring/washer on my 1980 KZ650 where I drain the oil?
Is it made of copper?
I havn't been everywhere - but it's on my list!
Re: Oil drain plug KZ650 - size of washer/o-ring?
11 Nov 2014 15:50 - 11 Nov 2014 15:52
I use a M12 aluminum gasket from the auto parts store. They usually come in packages of 2 or 3.
Last edit: 11 Nov 2014 15:52 by martin_csr.
11 Nov 2014 16:00
The genuine Kawasaki washer is aluminum. Ed
- Piilgard
12 Nov 2014 01:56
Thank you!
Do you guys know the size? Is the M12 a 12mm or is the standard 10?
12 Nov 2014 05:20
M12 = 12mm
12 Nov 2014 06:27 - 12 Nov 2014 06:29
The gasket ID is slightly larger than 12mm.
Partzilla is showing an oem price of 34 cents, so it might be cheaper to get a gasket at the Kaw dealer than the auto parts store. The Dorman pkg of 2 is about $2 at various places.
Last edit: 12 Nov 2014 06:29 by martin_csr.
