Muffler system gaskets - Aftermarket alternatives
  • martin_csr
  • martin_csr's Avatar Topic Author
09 Nov 2014 07:09 - 10 Nov 2014 05:27
#653235
Not the exhaust port gaskets. The donuts for the manifold connections. Stock gaskets are available on eebbaayy but can be pricy. Are there aftermarket donut gaskets available anywhere? Or is there an exhaust wrap fiber tape that could be used? Thanks.
Delkevic brand donut gaskets fit onto the #2 & #3 header pipes of the 81 650-CSR. The csr crossover pipe gaskets are smaller --- the nipple on the manifold is approx. 28.6 to 28.9mm OD.
MOTORCYCLE EXHAUST CRUSH GASKET EX250 250R NINJA --- PR1893
I think they're a graphite material (41x35x25mm --- $7).
Last edit: 10 Nov 2014 05:27 by martin_csr.
