Leaking oil from tachometer drive
  • New 750
  • New 750's Avatar Topic Author
30 Oct 2014 12:30
#652237
Like the tittle says, my question is I unscrewed the cable from the motor and pulled it free, how do I remove the oil seal? Can I repair this with the valve cover still on? I looked inside there all I see is the thing the tach cable slides into, I was tempted to pull that out as well with a pliers to access the seal. But was not sure.
1977 kawasaki KZ750
  • bountyhunter
  • bountyhunter's Avatar
Re: Leaking oil from tachometer drive
30 Oct 2014 15:20 - 30 Oct 2014 15:22
#652266
www.bikebandit.com/oem-parts/1977-kawasa...b/o/m150647#sch40450
Looks like there is a seal, gasket and O ring.
FYI: I finally got mine to stop leaking by making a gasket to seal where the cable flange butts against the drive piece.
Last edit: 30 Oct 2014 15:22 by bountyhunter.
