Intermittent Issues with starting
- blormis
28 Oct 2014 12:13
I picked up a 1994 KZ1000 in relatively good shape. There is an issue starting it up. I'm about to dig into it but I wanted to get some input from the community at large.
When I try and start it up, I hear a loud clicking noise (Batter has been tested and fully charged). If I put the bike into first gear and rocker it back and forth then click the start button I can get it to start sometimes. Any thoughts on what I should focus on? I was going to check the starter brushes and the starter clutch.
Cheers
-B
Cheers
-B
- baldy110
Re: Intermittent Issues with starting
28 Oct 2014 13:40
Starter solenoid under the left side cover.
- blormis
28 Oct 2014 16:17
Thanks for the response, i will check that out. I read I can also bypass the solenoid to test the starter as well. I'll give that a shot before I tear into anything.
Cheers!
-B
Cheers!
-B
- blormis
29 Oct 2014 11:42
Solenoid seems ok. I bypassed the solenoid and went straight from the battery to the starter, nothing happened. It seems like an issue with the starter. I am ordering a rebuild kit.
Cheers
-B
Cheers
-B
- baldy110
29 Oct 2014 11:48
Welcome to the wonderful world of trouble shooting.
