Valve adjusting when using other cams
  • accubond
  • accubond's Avatar Topic Author
27 Oct 2014 16:07
#651908
Now , that my engine is reasambled and running, i am looking for more low end power. I have the GPZ550 1981 engine with Zephyr 550 cylinders .
I have a spare KZ550 engine. Are the cams the same like in my GPZ550 engine? I read somewhere that KZ550 cams produce more low end power.
My question is: do i need to adjust the cams for sure? Or is it likley that valve clearance will be good with the KZ cams?
Thanks and regards
David
  • DFIGPZ
  • DFIGPZ's Avatar
Re: Valve adjusting when using other cams
27 Oct 2014 16:43
#651916
best to do a valve adjustment to verify clearance with other cams I think Kz550 cams and GPZ550 cams are different.
1984 750 Turbo
The following user(s) said Thank You: PLUMMEN
  • Tyrell Corp
  • Tyrell Corp's Avatar
27 Oct 2014 16:55
#651918
yes, the gpz cams are more 'cammy' , that 2 stroke style high rpm power band...that is the 'gpz tune'. Earlier kz550 cams are shorter duration and timed more for midrange.
Put the ZR cams back in it , they are the same as early kz550 i think. If you are really keen use the ZR cams with an airbox and 4-2 pipes. You could even 'dial in' the cams in for more bottom and mids with slotted cam sprockets,
The following user(s) said Thank You: accubond
  • accubond
27 Oct 2014 17:00 - 27 Oct 2014 17:01
#651920
I just have the Kz550 cams not the zr cams. I might give it a try if they have more low and midrange power. I am using a 4-1 absorption style exhaust. Just dont want to have to put in all new shims, so my biggest concern is : is it likley that the valve clearance is ok with the KZ550 cams
Last edit: 27 Oct 2014 17:01 by accubond.
  • PLUMMEN
  • PLUMMEN's Avatar
27 Oct 2014 17:08
#651922
Check the clearances when you reinstall/replace cams.
  • SWest
  • SWest's Avatar
  • 10 22 2014
27 Oct 2014 20:01
#651948
Good advice.
  • loudhvx
  • loudhvx's Avatar
28 Oct 2014 07:39
#651979
All that info is here:
home.comcast.net/~loudgpz/GPZweb/CamsKZZ...KZZXZR550500400.html
It shows how to identify the three types of 550 cams.
Once installed, you will have to re-do the valve clearance checks to verify the clearance.
  • SWest
  • SWest's Avatar
  • 10 22 2014
28 Oct 2014 08:25
#651982
Good advice. I hope the OP reads it. DANGER!
  • accubond
28 Oct 2014 08:26
#651983
What Danger? Regarding the valve cover?! Yeah I know. But thanks
  • loudhvx
  • loudhvx's Avatar
28 Oct 2014 08:40 - 28 Oct 2014 08:41
#651986
I had to over-do the "warning"... inside joke from the gpz550 forum. :)
But I posted the link because it has all of the details on the factory camshaft specs for various 550's.
Last edit: 28 Oct 2014 08:41 by loudhvx.
