Oil Seal Removal ( Tach Drive ) ???
  • kzdcw
  • kzdcw's Avatar Topic Author
  • 77' KZ1000A
20 Oct 2014 16:03
#651275
Purchased a New oil seal for the Tach Drive on my 77' KZ1000A. The FSM doesn't show how to change it out. Is there a trick on how to remove and replace it before I potentially bugger it up?
Is there a Gasket before the seal? Nothing appeared to be there before I removed the Tach Drive but the KZ Parts Lists shows one?
77' KZ1000A
  • TexasKZ
  • TexasKZ's Avatar
  • Away
Re: Oil Seal Removal ( Tach Drive ) ???
20 Oct 2014 16:12
#651277
Should be two gaskets and one o-ring I believe. There was a thread with pics just a couple of days ago.
  • TexasKZ
  • TexasKZ's Avatar
  • Away
20 Oct 2014 16:20
#651279
The discussion was about a 650, but I think the 1000 is the same
kzrider.com/forum/2-engine/596181-kz650-...il-from-speedo-cable
  • kzdcw
  • 77' KZ1000A
20 Oct 2014 16:29
#651281
Doesn't say how to remove it? I'll probably use a Dental Pick and see if I can carefully remove it.
77' KZ1000A
  • 74ullc
  • 74ullc's Avatar
20 Oct 2014 16:35
#651283
Gulf Coast, Texas
1977 KZ1000LTD
1984 VF700F
The following user(s) said Thank You: Patton
20 Oct 2014 16:43
#651284
You should replace items 7, 8, and 10. If it still leaks after that replace item 9. Ed
Attachment 00003a_2014-10-20.jpg not found
  • kzdcw
  • 77' KZ1000A
20 Oct 2014 17:36
#651288
Read the older Posts. Ed, I used a screw extractor bit to remove old seal. Didn't want to possibly scratch the inside of the tach drive if using a pick. Came out easy. Only ordered the Drive Seal from Z1 Ent. but it will be a while before I fire up the motor and possibly ride the bike to test.
I didn't see the paper seal sold individually thru Z1 Ent. Can try Partzilla at a later time if they have one? Or maybe I can make one? O-ring, I found a pretty close match out of my Nitrile O-ring kit that fit.
77' KZ1000A
20 Oct 2014 18:28 - 20 Oct 2014 18:29
#651290
Interesting approach. Personally, I wouldn't go through the effort of replacing the seal without also replacing the gasket and o-ring considering they only cost $3.92. Considering that they are most likely more than 35 years old it seems like they may need it. Ed
#7 - Gasket = $1.63 www.partzilla.com/search/?q=92065-103&x=0&y=0
#10 - O-ring = $2.29 www.partzilla.com/search/?q=92055-1149&x=9&y=12
Last edit: 20 Oct 2014 18:29 by 650ed.
  • kzdcw
  • 77' KZ1000A
20 Oct 2014 19:07
#651296
Certainly don't have the technical knowledge as you, but still have a few tricks up my sleeve for a backyard 60 year old tinkerer :laugh:
I'll put those 2 parts on the running list when I get closer to breathing life back into her !
77' KZ1000A
  • 74ullc
  • 74ullc's Avatar
20 Oct 2014 20:07
#651303
Is the red fibre washer the part y'all are referring to as the gasket? Check the thread I linked to for a photo. If that's it, as mentioned in my post, z1e does sell them but you have to call.
Gulf Coast, Texas
1977 KZ1000LTD
1984 VF700F
  • dkoz
  • dkoz's Avatar
20 Oct 2014 23:09
#651311
Z1enterprizes does sell the paper gasket. I ordered over the phone just as 74ullc stated . Some things at z1 I've found get left out on the Web in one search but turn up on another
or don't seem to be listed.
1978 LTD B2 smashed
1978 Z1R D1
1978 A2
  • 74ullc
  • 74ullc's Avatar
21 Oct 2014 10:31
#651333
I've been told over the phone by Z1E employees to search by part number if I'm having trouble finding something. The gasket/fibre washer didn't show up using that method but they do have it.....give 'em a shout.
Gulf Coast, Texas
1977 KZ1000LTD
1984 VF700F
