KZ550 engine rebuild -which o rings
  • accubond
  • accubond's Avatar Topic Author
20 Oct 2014 14:55
#651260
Hi,
i am rebuilding my KZ/GPZ engine. I lapped the valves , put new valve seals in and gonna replace the gaskets.
I have the 2 oval orings which go between head and cylinders. Are there between crankcase and cylinders also orings that need to be changed?
If yes how many and where? I think there are at least two right around the oil lines. Does someone know the measurements?
What else regarding the oil lines is essential`?
Thanks
Regards Dave
Re: KZ550 engine rebuild -which o rings
20 Oct 2014 15:15
#651262
Are you trying to rebuild the engine without using a Kawasaki manual for guidance? Ed
  • accubond
Re: Re:KZ550 engine rebuild -which o rings
20 Oct 2014 15:17
#651263
I do have a manual.
  • Tyrell Corp
  • Tyrell Corp's Avatar
20 Oct 2014 15:21
#651264
two oval O rings on the oil feed nozzles on block/cylinder head, also two O rings around oil feed nozzle at cranckcase/block . You should replace these and get a manualwhich you will likely need when setting cam timing, valve clearances, tourqing down head etc.
20 Oct 2014 15:22
#651265
I asked because my Kawasaki KZ650 manual is specific about installing new O-rings, how many, etc.. I'm surprised your manual isn't clear on the subject. Ed
  • Tyrell Corp
20 Oct 2014 15:25
#651266
ok..check the exploded parts diagrams , all the kz550 have the same oil nozzle O ring arrangement. The later models had an uprated part number (which can and should be retrofitted) the cylinder head nozzles have raised shrouds around them .oil leaks are a common problem here.
  • accubond
20 Oct 2014 15:30
#651269
I am using zr550 zephyr cylinders because they are mostly in better condition than GPz/kz cylinders here in germany. Can I use the old oil feed nozzles from the GPz? Or is it for some reason better to use the new ones with ears?
  • accubond
20 Oct 2014 16:00
#651273
I bought the original base and head gasket. Should I put on the base gasket a sealant?
  • accubond
21 Oct 2014 09:50 - 21 Oct 2014 09:52
#651331
Does anybody know what size the orings between crankcase and cylinders have? I would like to buy Viton rings at a hardware store.
Last edit: 21 Oct 2014 09:52 by accubond.
21 Oct 2014 10:10
#651332
Why not just use the genuine Kawasaki o-rings? That way you will know they will fit and they will last 30+ years. Considering they only cost around $8 for all 4 why take a chance by using unknown parts? Ed
  • accubond
21 Oct 2014 10:43
#651337
I don't want to wait for kawasaki to get the rings. Viton is a better material.
21 Oct 2014 11:27
#651344
How long would you need to wait? I usually get special order parts in about 4 days.
Regarding Viton, it is good material, but how much better than the original material can it be in real life terms? My original o-rings still don't leak and they are 37+ years old, so I can't see a practical advantage offered by Viton.
Good luck finding metric o-rings of the correct size and profile for both the nozzle and studs at your local hardware store. Hopefully they will be close enough so they don't leak and require an engine tear-down to replace. Ed
