removing dynamo rotor without puller
  • dkoz
  • dkoz's Avatar Topic Author
20 Oct 2014 12:04
#651246
I have a manual that says you can use a top cap bolt to do this along with a ball bearing .my top caps on both bikes are different ones .I'm stuck in a wheelchair and I can send the wife to the hardware store but I need to know the size of this bolt to use..anybody know? While I'm here any tips for splitting the stuff apart without using the proper tools :sick: Thanks
1978 LTD B2 smashed
1978 Z1R D1
1978 A2
  • zed1015
  • zed1015's Avatar
Re: removing dynamo rotor without puller
20 Oct 2014 12:20
#651247
Which bike ???
On the z900/1000 the swingarm spindle or rear wheel spindle can be used.
The following user(s) said Thank You: dkoz
  • bluezbike
  • bluezbike's Avatar
20 Oct 2014 12:23
#651248
I've done that before and it works......although I used the center bolt that goes through the steering neck, use the largest ball bearing you can that fits into the dynamo center hole without seizing
79 KZ 1000 LTD
  • dkoz
20 Oct 2014 13:37
#651254
problem solved thanks a bunch of guys
1978 LTD B2 smashed
1978 Z1R D1
1978 A2
  • Arial Bender
  • Arial Bender's Avatar
20 Oct 2014 14:15
#651259
zed1015 wrote: Which bike ???
From here
kzrider.com/forum/11-projects/594991-my-...unk-of-junk?start=40
78 Z1-R
