O-rings: Best ones to use & installing...
  • daveo
  • daveo's Avatar Topic Author
  • Premium Member
  • Premium Member
18 Oct 2014 20:46 - 19 Oct 2014 15:28
#651078
I will likely R&R the cylinder head on my J-motor over the winter. Along with the head-gaskets and center gasket, there's special rubber o-rings positioned at the four outer-most cylinder stud locations, intended to provide the seal against oil leakage where the oil flows through the head gaskets to valve-train components in the head. Three of the four have done their job.
The special Genuine Kawasaki O-rings have an oval-shaped cross section, and I'm wondering if anyone has tried using viton or silicone O-ring alternatives?
Otherwise, regarding the cleaning of rubber parts. Should special attention be given to these special O-rings, before placing them and squashing them with the head? Also, would a light application of "sealer" help the O-rings seal best? I want the longest-lasting assembly possible, this time around.
Thanks in advance for suggestions. ;)
1982 KZ1100-A2
Last edit: 19 Oct 2014 15:28 by daveo.
  • pete greek1
  • pete greek1's Avatar
Re: Cleaning O-rings (related)
19 Oct 2014 07:30
#651106
daveo, there is a thread going, about cleaning O rings in the carburetor section
Pete
  • daveo
  • Premium Member
  • Premium Member
Re: O-rings: Best ones to use & installing...
19 Oct 2014 15:27
#651155
Changed subject for clarification. :)
1982 KZ1100-A2
19 Oct 2014 15:42
#651157
If you can't find something else you want to try, I believe the genuine article is still available. Ed
www.z1enterprises.com/ItemDetails.aspx?i...Head&item=92055-1148
  • DFIGPZ
  • DFIGPZ's Avatar
19 Oct 2014 16:11
#651159
no sealer and use GENUINE orings.
1984 750 Turbo
  • daveo
  • Premium Member
  • Premium Member
19 Oct 2014 16:18
#651161
650ed wrote: If you can't find something else you want to try, I believe the genuine article is still available. Ed
Wondering exactly what O-rings the professional engine builders are using, and the recommended process for installing them.
Thanks!
1982 KZ1100-A2
  • Tyler
  • Tyler's Avatar
19 Oct 2014 16:35
#651163
I'm no pro, but I wouldn't use anything but a kawasaki o-ring. precise sizing is critical for them to seal. installation is easy, clean the seat area install new o-ring.
"74 Yamaha DT 400 Enduro
  • ezrider714
  • ezrider714's Avatar
19 Oct 2014 17:32
#651168
I wouldn't worry about them being "Kawasaki" parts just the correct Part No.
Kawasaki is not in the o-ring manufacturing business, they source these from an o-ring manufacturer to their specifications, if a reputable o-ring supplier has the correct Part No. I'd use it without hesitation... they probably made the part for Kawasaki :ohmy:
78 KZ650SR Mine since 79
4-1 Mac Jet Hot coated since mid 80's
Dyna Coils
Saddlebags (I ain't skeered of going nowhere) :)
  • Tyler
  • Tyler's Avatar
20 Oct 2014 00:14 - 20 Oct 2014 00:20
#651207
Well, it should be Genuine Kawasaki, meaning they sourced the part, not made it like most parts they used. Buying aftermarket, or using O-rings that come in some gasket kits is a bad idea ( most of the time). You can buy metric size O-rings a lot of places ( www.mcmaster.com ) or your local hardware store, but Kawasaki parts will be the correct size, diameter, and firmness to seal.
The point is that O-rings are such an inexpensive part, and if they don't seal the work and cost to replace them is so high - its best to get part that you know will work. That said Z 1 Enterprises has done a very through job of sourcing the correct parts as well and they have the correct equivalents as well as many OEM originals.
Last edit: 20 Oct 2014 00:20 by Tyler.
