KZ900 Cam timing: GPZ1100 camshaft swap
  • Richie7
  • Richie7's Avatar Topic Author
18 Oct 2014 18:30
#651065
Hi all,
I'm in the process of swapping the stock cams on my 76 kz900 with 83-84 gpz1100 cams.
What I'm wondering is if I should get ADJUSTABLE sprockets from APE (ACS900K) or FIXED sprockets (ACS900K-2B) for the job?
I'm not quite sure how GPZ1100s are timed, but I see that some of you successfully installed the gpz cams so...Your advice is greatly appreciated.
BTW, I'm swapping cams because my intake cam got damaged while I was tuning my bike a couple days ago. The shim on #1 intake slipped out of the bucket and shot through valve cover. Now, I've never seen that happened :S I'm pretty bummed as it was a fresh built motor with 500 miles on it, but I'll take it as an opportunity for upgrades(i.e. porting, high lift cams, gas tank paint finally, etc...) :)
1976 KZ900A4
98 CBR900RR Front End
01 GSXR1000 Swingarm + Wheel
Wiseco 1015cc Piston Kit
Dyna ignition + Accell Coils
VM28 Pumpers
  • 60ratrod
  • 60ratrod's Avatar
Re: KZ900 Cam timing: GPZ1100 camshaft swap
19 Oct 2014 00:02
#651088
Did you change your shorts too? Mine woulda looked like I sat in some grease.
Active Duty US Navy Aviation Ordnanceman Petty Officer First Class
81 kz1000m1 csr "Sarge"
81 Suzuki gs650g "Shelah"
  • zed1015
  • zed1015's Avatar
19 Oct 2014 02:02 - 19 Oct 2014 02:07
#651094
You need the ACS900K-2B converter sprockets as these fit the 2 bolt GPZ camshaft ( The 2B denotes 2 bolt holes )
The ACS900K will not fit the GPZ cam as these are 3 bolt fitment.
BOTH types are adjustable.
Using the 83 GPZ unitrack cam it is recommended that you convert to under the bucket shim arrangement to avoid a repeat of the shim spitting incident.
Last edit: 19 Oct 2014 02:07 by zed1015.
  • Richie7
19 Oct 2014 07:47
#651109
I caught it fast enough to not spill oil all over myself ;)
1976 KZ900A4
VM28 Pumpers
  • Richie7
19 Oct 2014 07:50
#651110
zed1015 wrote: You need the ACS900K-2B converter sprockets as these fit the 2 bolt GPZ camshaft ( The 2B denotes 2 bolt holes )
Perfect, That's exactly what I needed to know. Thank you.
1976 KZ900A4
VM28 Pumpers
