Tach seal leak won't stop
  • SeattleKZ
  • SeattleKZ's Avatar Topic Author
11 Oct 2014 07:51
#650331
I put in a new tach drive seal and it seems to leak even more. Is there a fix for this?
This is in regards to a 1976 KZ900
Re: Tach seal leak won't stop
11 Oct 2014 09:00 - 12 Oct 2014 07:30
#650349
Rendering Error in layout Message/Item: Kunena\Forum\Libraries\BBCode\KunenaBBCodeLibrary::renderEbayLayout(): Argument #1 ($ItemID) must be of type int, string given, called in /home/kzride5/public_html/libraries/kunena/src/BBCode/KunenaBBCode.php on line 314. Please enable debug mode for more information.
  • SeattleKZ
11 Oct 2014 09:17
#650352
Thanks
11 Oct 2014 09:38 - 11 Oct 2014 09:42
#650354
Both the shaft seal and o'ring(s) serve to prevent oil from escaping through or around the tach drive.
The tach shaft seal prevents oil from escaping around the shaft.
The o'ring around the tach drive case prevents oil from escaping past the case.
Am thinking that some models may have 2 o'rings around the tach drive case.
Even without the tach cable installed, there should be no leakage whatsoever from the tach drive. For example, after a cross-country ride without a tach cable, the exposed end of the tach drive shaft should be perfectly dry and oil-free.
Without the tach cable attached, should be able to see the end of the tach drive shaft, and watch it spinning when the engine is running.
Using an oil-tight connection between the cable and a leaking drive simply allows the escaping oil to accumulate inside the cable. And is a band-aid effort in lieu of a correct repair.
Hopefully, there 's no damage to the engine where the tach drive fits.
But sometimes JBWeld might serve as a feasible repair.
Good Fortune! :)
Last edit: 11 Oct 2014 09:42 by Patton.
