on 1000 engines, the points housing top left bolt needs ample thread sealer.
the bolt hole is drilled and taped all the way through into the crankcase.
odds are your be ok without sealer, but they have and will weep oil at this bolt. Mine did?
as for these gaskets, install dry.
