Oil cooler junction?
  • Lmdgr34
  • Lmdgr34's Avatar Topic Author
09 Oct 2014 16:09
#650191
My question is do I need that junction tube or whatever that is for my oil cooler setup? It is leak city and as you can see in the pictures it appears that it is rubbing away at the top of the valve cover??!! Any harm in replacing that thing for just two braided lines?
1976 KZ900
29mm smoothbores, pod filters, 4-1 pipe....and a whole lot of daydreaming
  • Cal
  • Cal's Avatar
Re: Oil cooler junction?
09 Oct 2014 16:51
#650192
That looks like an in line thermostat,,,if so,u really only need one if you ride in cool temps,,i think it opens around 160-180 degrees
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
09 Oct 2014 17:32
#650199
Shit Can it and just run new lines. Watch your line routing as the steel braid will act like a saw if it rubs anything
  • Lmdgr34
28 Oct 2014 20:54
#652049
Took off the thermostat discovered this mess, larger hose around smaller hose around inlet...
Upon further inspection the cooler is gummed up, so while I am cleaning that out can I just connect a hose between these two and run it in the mean time?
1976 KZ900
  • kaw-a-holic
  • kaw-a-holic's Avatar
Re: Re:Oil cooler junction?
28 Oct 2014 21:59
#652054
Yes, it's just an inlet and outlet.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
