Polishing the intake- and exhaust port???
- Winkler
07 Oct 2014 12:21
Hey guys,
Is the HP increased by polishing the intake- and exhaust port on a motorcycle or my KZ750 B1??
I read somewhere that the rough surface inside the intake port was helping to mix the fuel and air before entering the combustion chamber? Is that true?
Would you recommend to polish the intake and exhaust port?
Kind regards Andreas
KZ750 B1 1976
- zed1015
Re: Polishing the intake- and exhaust port???
07 Oct 2014 12:39
It's worth polishing the exhaust to reduce carbon build up but leave the inlet un-polished to aid atomisation.
In truth you probably wont tell any difference as it is the port shape that aids power and removing material from the wrong area can create unwanted turbulence and actually reduce power.
If you don't know what you are doing I would minimise the work to just smoothing out any step between the intake rubber and port .
The following user(s) said Thank You: PLUMMEN
- wireman
07 Oct 2014 17:38Attachment 90s.jpg not found
easiest way I can think to explain porting a head.its not size that's important,iits how it transisions from one end to the other that makes the biggest difference.
- Tyler
07 Oct 2014 21:35
The debate over polishing is as old as the combustion engine. In theory a polished surface has more friction to an enclosed turbulent flow. Why? Because the laminar boundary layer acts as a buffer between the material surface and the free stream within the pipe (or intake runner). Reducing surface roughness reduces the thickness of the laminar boundary layer and thus increase the pressure drop though an enclosed flow duct due to friction. This is a well known principle of fluid mechanics. Strangely enough engine builders have shown in some cases that polishing can actually increase flow despite the fact that we would expect just the opposite.
What is my point with all of this? Well if you don't have any first hand knowledge with exactly what you are doing when polishing a intake port runner, then don't do it. In practice intake ports should be left with a some surface roughness like a bead blasted finish and exhaust ports are polished smooth to prevent carbon build up.
More important than the surface treatment, the transitions are what you need to spend time on, specifically the entrance to the intake manifold and the valve seat area ( bowl work). Again if you have no first hand knowledge of what to do, leave it alone.
"74 Yamaha DT 400 Enduro
08 Oct 2014 04:56
On a purely stock engine, I'd be really surprised if polishing added any measurable power. Correctly reshaping the ports might gain a pony or two, but the ports on most of these engines already flow just about as much as a stock engine can take.
- Winkler
19 Oct 2014 13:55
Again thank you guys!!
I really appreciate your time and respons. I will stay away from the inlet and polish up the exhaust outlet to reduce carbon blockage.
KZ750 B1 1976
