oversize head gasket 'fit'
- Tyrell Corp
06 Oct 2014 12:03 - 06 Oct 2014 12:10
I need an obsolete and unavailable 60.25mm GPz550 596cc Yoshimura head gasket, I either I bore out an NOS z500cc Moriwaki 3 piece composite, bore out a new kawasaki 550cc 58.00mm or use a wiseco 615cc 62mm size,
If I used the 62.00 mm wiseco head gasket on the 60.25mm bore, would would 0.75mm 0.030" bore to head gasket clearance be too wide?
Apart from a slight reduction in compression ratio, which could be handy as they are 12:1 3 ring cast pistons... any potential problems with this ?
Last edit: 06 Oct 2014 12:10 by Tyrell Corp.
Re: oversize head gasket 'fit'
06 Oct 2014 15:52
The Wiseco gasket should be fine. Suzuki uses the same head gasket for GS850-1100 despite significantly different bore sizes.
The following user(s) said Thank You: Tyrell Corp
- Tyrell Corp
07 Oct 2014 07:31
Thanks, would a bored out original MLM metal 3 piece laminated gasket be better than a Cometic graphite and steel type for this high compression application?
- turboking
07 Oct 2014 07:58
I've run cometic graphite/steel gaskets on turbo street engines with 18 plus psi of boost :whistle: .....wiseco/cometic does the" fits all" sizing on a few of the gaskets for engines that they sell :blink: . be sure that you use NO sealer on the head gasket.and cylinder and head surfaces are oil free........ :dry: they seal great and last...
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
1985 GS 1150E
1983 GS 1100E
