1980 kz750 four weird noise
  • koloj
  • koloj's Avatar Topic Author
03 Oct 2014 16:44
#649588
The noise sounds right behind the shifter plate... Like a gurgling and I know the starter clutch is going bad but what would that gurgle noise be... Rides good in all gears
Re: 1980 kz750 four weird noise
04 Oct 2014 03:00
#649623
koloj wrote: The noise sounds right behind the shifter plate... Like a gurgling and I know the starter clutch is going bad but what would that gurgle noise be... Rides good in all gears
If not already done, would assure that the nut that holds the counter-shaft sprocket in position on the output shaft is tight and hasn't loosened.
Good Fortune! :)
  • koloj
Re: Re:1980 kz750 four weird noise
07 Oct 2014 18:20
#650012
Yea that's tight do u think a cracked starter clutch plate would make a noise when I Rev it sounds like it right in that area
  • koloj
07 Oct 2014 18:21
#650013
Kinda like a knock but only does it when I'm giving it high revs not if I'm costing normal
  • koloj
07 Oct 2014 18:22
#650014
It's not the cam chain or a piston knock comes from the starter area between the breather and starter
