head gasket layers?
  • Zaddict
  • Zaddict's Avatar Topic Author
  • Enjoying my Zaddiction!
head gasket layers?
03 Oct 2014 12:12
#649535
I've never pulled the head - I was surprised to see a metal head gasket with three layers. Is that normal or did someone put three gaskets on for some reason (to stop a leak maybe)?
New ones are pricey. I'm thinking about reusing the old one, but you all can probably tell me how bad an idea that is.
Thanks
Attachment photo-8.jpg not found
1990 Zephyr zr550 B1
Wiseco 615cc kit
zx550 cams
SPII ignition system
Kerker stainless steel race exhaust with 1.5" competition baffle
K&N Air Filter...
  • Tyrell Corp
  • Tyrell Corp's Avatar
Re: head gasket layers?
03 Oct 2014 14:08
#649566
It is a laminated gasket, I think moriwaki used first them so kawasaki copied them.
The older zeds had a one piece gasket originally, but the part number was superseded by the 3 peice laminated type.
Don't re- use it, once clamped down and a few heat cycles and you won't get a proper seal. Also replace the oil feed O rings at the side.
  • steell
  • steell's Avatar
06 Oct 2014 11:03
#649828
MLS = Multi Layer Steel, arguably the best head gasket type available.
