Found a crack !!!
- kzdcw
- 77' KZ1000A
Found a crack !!!
02 Oct 2014 13:04
My left chain sprocket cover off my 77' KZ1000A has a crack on the lower right cover bolt and curves to the left just downstream of the shifter shaft cover hole. Crack is about an 1 1/4" long. Besides having it welded, is there something that you would recommend to use to bond the crack on the backside of the cover? JB Weld perhaps or something else?
77' KZ1000A
- StreetfighterKz
Re: Re:Found a crack !!!
02 Oct 2014 13:22
Instead of having it welded you could probably just get another cover unless that one is desirable.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
The following user(s) said Thank You: PLUMMEN
- kzdcw
- 77' KZ1000A
02 Oct 2014 14:02 - 02 Oct 2014 14:37
Doug, No the cover is not desirable but would like to repair it. Haven't priced another cover yet? What is this foam rubber insulator thing inside the cover? Is it some sort noise suppressor? Are the even available any more? Mine is getting a bit worn but what do you expect for 37 years old.
77' KZ1000A
Last edit: 02 Oct 2014 14:37 by kzdcw.
- StreetfighterKz
02 Oct 2014 14:38
Ok. Normally the covers crack when the small dowel pins aren't lined up between the cover and case halves.
Later, Doug
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- StreetfighterKz
02 Oct 2014 14:45
The foam with the metal screen is just for noise insulation just like you mentioned. The Z1's didn't have it due to the chain oiler.
Later, Doug
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- moneypit
02 Oct 2014 15:36
2-76 kz900
St Paul MN
St Paul MN
- kzdcw
- 77' KZ1000A
03 Oct 2014 09:08
I think I'm going to try a little JB Weld or similar Metal Epoxy first, before replacing the cover.
77' KZ1000A
- saxjonz
- KawboyZ
03 Oct 2014 09:21
Waste of time and effort. Check out fleabay. I bought one for around 10 dollars maybe 20 with shipping. They aren't worth trying to fix. Trust me, I broke mine the same way, just like Doug mentioned. I didn't misalign the dowel, I placed it in wrong hole and when I torqued it I heard it crack. Oh well, its been replaced with one that looks exactly same condition. Don't sweat it.
kzdcw wrote: I think I'm going to try a little JB Weld or similar Metal Epoxy first, before replacing the cover.
79 LTD B3
- kzdcw
- 77' KZ1000A
03 Oct 2014 12:10
Appreciate the insight from all, but had some JB Weld already so doesn't cost anything to try. If it doesn't work I'll purchase another cover.
77' KZ1000A
