96 1000J
- HBKwaka
96 1000J
02 Oct 2014 10:51 - 02 Oct 2014 11:04Attachment DSC00246.jpg not found
Attachment DSC00247.jpg not found
Looking for cam cap number 3 for a 96 1000J. If I have to buy a set or individual does someone have some or where to find? TIA
Last edit: 02 Oct 2014 11:04 by HBKwaka.
- HBKwaka
Last edit: 02 Oct 2014 11:41 by HBKwaka.
- PLUMMEN
Re: 96 1000J
02 Oct 2014 11:41 - 02 Oct 2014 11:44
Any j series head cap should fit your head,The more of them you have to choose from the better the chances of finding one that's close,Id strip the head down first so you can spin the cam and check for tight spots.Id also plastigauge it to check for bearing clearance.
The number shouldn't make any difference,its the clearance you need to worry about.
Last edit: 02 Oct 2014 11:44 by PLUMMEN.
- HBKwaka
Re: 96 1000J
02 Oct 2014 11:43
The head is disassembled. #3 isn't on the head. NEVER believe that cop mechs are G2G.
- [email protected]
Re: 96 1000J
03 Oct 2014 16:36
Be careful. The cam caps were cast with the head -- then machined. So they fit like puzzle pieces. Golden rule is you never replace or swap a cap. But it you have no choice, inspect alignment and oil clearance carefully. In some cases the cam won't even turn with a foreign cap installed.
- HBKwaka
Re: 96 1000J
06 Oct 2014 13:43
Sadly this issue maybe the end of attempt to get this thing running.
- HBKwaka
Re: 96 1000J
07 Oct 2014 17:33
Well belay my last. Ole Kawman has saved my engine from the parts bin. Move along, nothing to see yet
