OEM chain and sprocket sizes??
  • kawasakisubaru
  • kawasakisubaru's Avatar Topic Author
29 Sep 2014 22:22
#649168
I am looking to change out the OEM chain and rear sprocket on my '80 KZ750E
I just bought the bike and it needs some work. the chain is pretty fucked.
Ive heard the OEM size is 630x84 with a 32t rear sprocket, but I've also heard 530x106
Does anyone here know?
If not, what is a good chain and sprocket combo to run?
1980 KZ750 E1
Kerker by Kawasaki 4-1 exhaust
Lockhart oil cooler
Mikuni VM29 smoothbore carbs
Pingel high flow petcock
Dunlop K70s
Custom brat style seat
Clubman bars
Dime city cycles 1.5in tach/speedo
Ox blood grips
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: OEM chain and sprocket sizes??
30 Sep 2014 01:13
#649171
Rear sprocket is 33 tooth and chain is 630 X 84...according to Mother Kawasaki :)
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
30 Sep 2014 06:57
#649178
Replace the front sprocket at the same time as the rear sprocket and chain. This is necessary because a worn sprocket will prematurely kill a chain and a worn chain will kill a sprocket. The wear on the teeth of your front sprocket, even if it doesn't look terrible, makes the spacing between teeth a little different than that of a new chain. As a result, the chain will quickly wear until its spacing matches that of the sprocket, and that leaves you with a prematurely worn out chain. Ed
