Backfiring
- KZBrett
Re: Backfiring
28 Nov 2014 16:30
720. To be sure we're on the same page that's 2 full turns.
Like if you marked the top, it would start at the top, turn 1 full turn back to the top.
2006 CBR800RR
1981 KZ750 LTD H2
1981 KZ750 LTD H2
- KZBrett
Re: Backfiring
28 Nov 2014 16:38
Hey Patton.
I've verified everything number and wiring wise.
I finally just bought some sea foam and ran it through.
It's getting better but it hasn't been fixed yet.
Cylinders 1-3 sizzle when sprayed and now 4 will a little.
They're all now too hot to touch. Before I could hold 4 no problem.
I think the not getting fuel post was right. I'm going to clean them.
Again... Lol. Then run more sea foam and hopefully be fixed up.
Thanks again guys!
Thanks again guys!
2006 CBR800RR
1981 KZ750 LTD H2
1981 KZ750 LTD H2
- !Seymore
- Ride on...
Re: Backfiring
29 Nov 2014 11:42
If you have access to an air compressor, or even compressed air in a can, spray carb cleaner thru the passageways of the carbs, watching where the liquid exists... and follow this with compressed air. We're talking about small passageways that are easily clogged/blocked. You'll be able to see if there are any restrictions to the spray cleaner.
C.
79' KZ650-D2 [fsm] (Max)
83' KZ750-F1 LTD [clymers] (Kay)
82' KZ1100-D1 Specter (another project)
78' KZ650-B2a (J&H, A Project)
91' KZ1000-P (P = parts)
- LineArtist
Re: Backfiring
29 Nov 2014 15:13
Points and timing - after the carbs are clean (take them ALL apart, and clean/inspect piece by piece. dumping anything into the gas tank is only a temporary fix).
'79 KZ650B3 (stock)
'79 KZ650B3 (parts bike)
'06 HD 883R
'06 HD 883R
