Annealing circlips 13mm 08mm
  • Tyrell Corp
  • Tyrell Corp's Avatar Topic Author
21 Sep 2014 17:40
#648301
Anyone tried annealing used circlips?
Need some 0.8mm x 13mm for a GPz550 Yoshimura kit, unavailable NOS so my only other option is teflon buttons. Any ideas?
  • PLUMMEN
  • PLUMMEN's Avatar
Re: Annealing circlips 13mm 08mm
21 Sep 2014 17:58
#648306
Id go with the buttons ;)
The following user(s) said Thank You: Tyrell Corp
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
21 Sep 2014 18:15 - 21 Sep 2014 18:22
#648312
Rendering Error in layout Message/Item: Kunena\Forum\Libraries\BBCode\KunenaBBCodeLibrary::renderEbayLayout(): Argument #1 ($ItemID) must be of type int, string given, called in /home/kzride5/public_html/libraries/kunena/src/BBCode/KunenaBBCode.php on line 314. Please enable debug mode for more information.
  • Nessism
  • Nessism's Avatar
21 Sep 2014 19:11
#648316
Annealing will soften the metal. Worst thing you could do.
  • Tomolu5
  • Tomolu5's Avatar
Re: Re:Re: Annealing circlips 13mm 08mm
21 Sep 2014 21:24
#648323
PLUMMEN wrote: Id go with the buttons ;)
+1
Mine:
04 Honda rebel 250(wifes)
04 GSXR 750(bolt on galore)
98 CBR 600F3(filter, pipe, adjustable cam sprokets, dyno tune)
76 KZ900A (LTD gauge pods, crash bars, LTD(style)pipes, dyna coils and ignition,headwork and mild port cleanup by cavanaugh racing, K&N filter pods, heck I dunno.
  • Tyrell Corp
22 Sep 2014 17:04
#648389
The 13mm circlip is unusual but there is a few non kawasaki models using that - the 0.8mm wire thickness is the difficult bit. Teflon buttons it is then.
