kick starter
- gtrain
kick starter
20 Sep 2014 04:02 - 20 Sep 2014 16:01
Hi, looking for a little help with my project.
I rebuilt my Z900 engine, reco head new pistons bored, cam chain and all the other bits & bobs,
Put it back into the frame fitted kick starter, first the kicker wouldn't return and now it won't move at all. I hope I don't
have to strip the motor again, what have I done wrong, cheers.
Last edit: 20 Sep 2014 16:01 by gtrain.
- bluezbike
Re: kick starter
20 Sep 2014 07:41
It may just be that you installed the return spring wrong......take the small cover off ( before you get into the major strip down) take out the spring and re-install it, it is a bit tricky, Do you have a service manual to help you?
79 KZ 1000 LTD
- gtrain
- bluezbike
Re: kick starter
20 Sep 2014 21:07
I will assume you have a service manual (hopefully the factory one) if you did the rebuild yourself so that should have all the pics and directions you need...
79 KZ 1000 LTD
- gtrain
Re: kick starter
20 Sep 2014 23:44 - 21 Sep 2014 00:45
Thanks worked it out, I hadn't rotated the shaft fully clockwise before fitting the return spring, cheering about that.
Last edit: 21 Sep 2014 00:45 by gtrain.
- gtrain
Re: kick starter
05 Nov 2014 01:17
starting to come together!
Attachment not found
- kaw-a-holic
Re: kick starter
05 Nov 2014 06:09
Glad to hear it worked out. Build is looking good. Keep the pics coming!
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
1977 KZ1000a1
Mesa, AZ
