kz305ltd gaskets
  • Janz3n
  • Janz3n's Avatar Topic Author
kz305ltd gaskets
19 Sep 2014 14:47
#648092
not sure if anyone will know the answer to this but im looking to rebuild my kz305 ltd engine this winter. seems as though theres more support for the csr and im not sure if theres even a difference in engines. was wondering if it matters which rebuild kit i buy before i order one?
81 kz305 ltd
  • Janz3n
Re: kz305ltd gaskets
24 Sep 2014 03:21
#648607
anyone? would love to order all parts this weekend. tried registering on kz400.com to ask but it wont send me a confirmation email.
81 kz305 ltd
  • !Seymore
  • !Seymore's Avatar
  • Ride on...
24 Sep 2014 10:43
#648633
A couple things, in this regard...
- Check the Kawasaki site and compare model # from the CSR and your bike. You can start here... and follow the bouncing ball: www.kawasaki.com/DefaultFrame.aspx?strCo.../VICHOOSEVEHICLE.ASP
- RE: the confirmation email, might check your SPAM folder in the email acct. I've seen them get tossed there... sometimes. GL...
C.
79' KZ650-D2 [fsm] (Max)
83' KZ750-F1 LTD [clymers] (Kay)
82' KZ1100-D1 Specter (another project)
78' KZ650-B2a (J&H, A Project)
91' KZ1000-P (P = parts)
  • Nessism
  • Nessism's Avatar
24 Sep 2014 18:38
#648687
OEM gaskets are superior to aftermarket in most cases. I'd stay clear of gasket kits because Kawasaki sells gaskets individualy, not in kits.
  • Janz3n
27 Sep 2014 09:25
#648949
only problem with that is there are a lot of parts that are discontinued that i really need like a cam seal behind the breaker points.
81 kz305 ltd
  • chonus
  • chonus's Avatar
27 Sep 2014 09:39
#648950
I replaced mine about 4 years ago. don't remember where I got it from but it wasn't difficult to get a hold of. try a cheapy if you can find one. it only takes 5 min to change if it still leaks and youre only out less than $10 hopefully
-Dave
'82 kz305 lil bob
'82 kz1000 streetfighter project
'80 kz750/4 LTD
'02 kx125
  • Janz3n
27 Sep 2014 14:06
#648962
81 kz305 ltd
