Gaskets seeping
  • calvinhobbesfan92
  • calvinhobbesfan92's Avatar Topic Author
Gaskets seeping
18 Sep 2014 07:59
#647942
Hi everybody. I recently went on vacation and stored my bike in a garage for about 10 days. When I came back my bike (which up until now has never leaked a drop) developed a couple oil seeps around the head gasket. Very small but leaking none the less.
My questions is this- is there something I can add to my oil that will revitalize the gaskets until I have time to tear everything apart and replace with new gaskets? Since its an 83 I'm planning on replacing all the gaskets and doing a full tune up this winter.
83 Kawasaki Spectre 550 Bobber
  • pete greek1
  • pete greek1's Avatar
Re: Gaskets seeping
18 Sep 2014 08:13
#647944
Head gasket or cam cover gasket
either way, you can try torqueing the nuts down with the engine cold to the right foot or inch lbs. & in the proper sequence according to the FSM for your bike, & that Might fix the problem
Pete
The following user(s) said Thank You: PLUMMEN
Re: Gaskets seeping
18 Sep 2014 09:25
#647957
When is the last time the oil was changed, and what oil is in the bike? Ed
  • calvinhobbesfan92
Re: Gaskets seeping
18 Sep 2014 10:49 - 18 Sep 2014 10:50
#647963
Oil was changed about 100 miles ago. Still pretty fresh. I just used Valvoline 10w40.
Just had an electrical fire under my seat pan 30 mins ago. Looks like I won't be riding till I get that figured out. Any electrical gurus here?
Last edit: 18 Sep 2014 10:50 by calvinhobbesfan92.
Re: Gaskets seeping
18 Sep 2014 12:15
#647979
If it's Valvoline CAR oil it will ruin your clutch. You need to use oil that has JASO-MA marked on the container. I doubt the Valvoline is causing the leak. Ed
  • bountyhunter
  • bountyhunter's Avatar
Re: Gaskets seeping
18 Sep 2014 13:55
#647985
calvinhobbesfan92 wrote: Oil was changed about 100 miles ago. Still pretty fresh. I just used Valvoline 10w40.
Sounds like a "hard" short to get a fire going. It means it's main wiring that doesn't go through a fuse like wiring to and from the battery or starter can do it.
Is the wiring stock or has somebody modified it?
  • calvinhobbesfan92
Re: Gaskets seeping
19 Sep 2014 06:54
#648050
It has been modified. The last owner spliced two LED strips for brake light and turn signals. I took those off when I purchased the bike. I guess the only thing to do now is to take my wiring diagram and trace everything. Or, buy a new wiring harness with no cuts!
