What would cause a friction plate to crack?
  • Grnole
  • Grnole's Avatar Topic Author
17 Sep 2014 08:45
#647848
Lost the ability to get into first, or second or any gear -
pulled the case bolts to reveal the first friction plate cracked... It looks like a new plate --- and the PO had claimed to have recently replaced them with an "upgraded EBC kit"
any tips on what else I should look for after replacing springs and friction plates?
1980 KZ1000 LTD -B4
1984 Yamaha FJ1100
1972 Honda CL350 (sold)
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
Re: What would cause a friction plate to crack?
17 Sep 2014 08:49 - 17 Sep 2014 14:15
#647849
If you were slamming thought gears either way.
If your metals are bent or warped and frictions are straight.....doesn't take much.
Could be a bad plate, to much heat in the plate or clutch. Clutch hanging or slipping just to name a few.
Just set metals on a flat surface and see if warped.
Check main pressure plate and if the clutch basket is free of notches where the plates enter the basket..... this can cause a problem if its notched, will catch the plate if notched.
Last edit: 17 Sep 2014 14:15 by 4TheKZ1000.
  • Grnole
17 Sep 2014 08:52
#647850
word. thats what i thought. Metals look good. Shall see how it goes.
1980 KZ1000 LTD -B4
1984 Yamaha FJ1100
17 Sep 2014 11:36
#647858
Did you happen to notice how many friction plates and steel plates are in there? I believe some aftermarket kits contain an extra pair, but I would think all the plates must be a little thinner for the extra plates to fit. If you decide to replace them I recommend the stock plates as they work great and last MANY miles. Ed
The following user(s) said Thank You: PLUMMEN, bluezbike
