LTD Exhaust
- kzdcw
- 77' KZ1000A
LTD Exhaust
12 Sep 2014 21:01
I'm pretty sure that I know the answer, but 76' LTD 900 with Vance and Hines exhaust system. Will this exhaust system fit my 77' KZ1000A? Not sure in the muffler mounting bracket or tab how that would mount to my 77'?
77' KZ1000A
- PLUMMEN
Re: LTD Exhaust
12 Sep 2014 21:14
You will have to make a rear mounting bracket,no big deal.The A has different rear peg brackets in 77-78 compared to the ltd.
- kzdcw
- 77' KZ1000A
Re: LTD Exhaust
12 Sep 2014 21:24
Plummen, Do you know if the rear peg bracket of my KZ is further back or further ahead of the LTD? I'm assuming there is a weld on tab of the muffler of the LTD V&H system that doesn't line up to my rear passenger peg mount? So the mounting bracket that I think your making reference to is probably a metal strap with a hole on each end? And that strap would mount to the muffler on one end and the other end to the passenger peg mount? Am I visualizing this correctly?
77' KZ1000A
- HBKwaka
- PLUMMEN
Re: LTD Exhaust
13 Sep 2014 16:46
The bracket for the 77-78 A series is higher uo the frame tube,most bikes need to have an extra bracket between the frame mount and the megaphone bracket anyway.
- kzdcw
- 77' KZ1000A
Re: LTD Exhaust
13 Sep 2014 22:02
Plummen, So with LTD system , the muffler would hang down lower than the Standard KZ ?
77' KZ1000A
- PLUMMEN
Re: LTD Exhaust
13 Sep 2014 22:24
The exhaust fits the same,its just a matter of the brackets
- kzdcw
- 77' KZ1000A
Re: LTD Exhaust
14 Sep 2014 13:03
So I'm assuming that raising the muffler if needed doesn't affect how the header pipes seat in the exhaust ports?
77' KZ1000A
- pete greek1
Re: LTD Exhaust
14 Sep 2014 14:40
NO Duane, you can only raise or lower the muffler so much, before you start putting excess pressure on the exhaust flange studs, that's why you'll have to make some sort of bracket
for instance, this is my 76 LTD with a Kerker, I made a 3 inch bracket from the muffler flange to the foot peg hole
The following user(s) said Thank You: PLUMMEN
- pete greek1
Re: LTD Exhaust
14 Sep 2014 14:45
- kzdcw
- 77' KZ1000A
Re: LTD Exhaust
14 Sep 2014 15:34
I'm pretty sure that the weld on tab on the LTD muffler is approximately 2" further back than it would be on the KZ muffler, therefore the tab of the LTD muffler and passenger peg mount on the KZ would not line up. I'm thinking you would have to make some sort of "Horizontal" bracket to connect the two? So instead of a vertical mounting adapter bracket, it would be mounted horizontally and I don't know how that would work?
77' KZ1000A
- saxjonz
- KawboyZ
Re: LTD Exhaust
15 Sep 2014 11:12
I had to deal with that problem as well. As you see I don't have a 75-6 with different mounts. Mine looks just like pete's post. I have a custom bracket to make it work. One straight piece of metal bent at two places and it will mount right up.
I'll post up a picture of it shortly.
79 LTD B3
