cam timing article
  • nads.com
  • nads.com's Avatar Topic Author
cam timing article
12 Sep 2014 00:49
#647205
The April 1st 2001 Hot Rod Magazine has the best article that explains how lca relates to power band.
And my power band is going to change. And I don't care about blow down, I don't want the door
open on the intake after the rise. I don't want the reversion, the fact that im choking the head,
the lack of peak torque . I will reluctantly try what makes power, ill try iit. Like ignition timing,
what gets advanced will get retarded at the end of the day.
