Tell me what this is
  • Novagraham
  • Novagraham's Avatar Topic Author
10 Sep 2014 17:20
#647071
I took the chain cover because I had a small oil leak can someone tell me what the hole to the right of the front sprocket is I have oil dumping out of it now like I accidentally unplugged it or somethjng
  • martin_csr
  • martin_csr's Avatar
Re: Tell me what this is
10 Sep 2014 17:41 - 11 Sep 2014 05:17
#647076
I guess you mean to the left of the sprocket? That's where the clutch push rod goes.
Unrelated, it seems that the sprocket washer is kinda messed up.
Also, I would clean up the neutral light switch connector & crimp the wire terminal a tad to get a good tight fit.
Last edit: 11 Sep 2014 05:17 by martin_csr.
The following user(s) said Thank You: PLUMMEN
  • Novagraham
10 Sep 2014 18:00
#647078
Thanks I guess my pushrod fell off or something and thanks for the tips
  • PLUMMEN
  • PLUMMEN's Avatar
10 Sep 2014 18:13
#647079
Its about a foot long depending on what motor you have,if it just falls out its pretty easy to notice. :laugh:
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
10 Sep 2014 18:23
#647081
:whistle:
  • Novagraham
10 Sep 2014 18:58
#647085
Yea I found it on the ground in the garage, bike is in a different city than I live in so the lapse of about a month I forgot what happened, all better now thanks
  • bluezbike
  • bluezbike's Avatar
10 Sep 2014 21:44
#647105
There should also be a loose ball bearing that fits between the push rod and the clutch release plate....make sure that hasn't gone for a stroll around your garage too if it's a KZ 900/1000....by the way what bike do you have?
79 KZ 1000 LTD
  • Novagraham
10 Sep 2014 21:46
#647106
1980 Kz750e 4 sorry should have included that does above bike have the loose ball bearing
  • loudhvx
  • loudhvx's Avatar
11 Sep 2014 11:13 - 11 Sep 2014 11:14
#647147
The ball bearing can't fall out, on the sprocket side, on a 550, and I think the same is true for the 750.
It can fall out on the clutch side.
Last edit: 11 Sep 2014 11:14 by loudhvx.
  • bluezbike
11 Sep 2014 11:20
#647149
loudhvx wrote: The ball bearing can't fall out, on the sprocket side, on a 550, and I think the same is true for the 750.
Very true, my mistake..... :laugh:
79 KZ 1000 LTD
