cooling system check
- Dukesy
10 Sep 2014 16:14
Hi all,
I concerned that there's no flow in the cooling system of my Z1300. Is there a way to check ?
- Tyler
Re: cooling system check
10 Sep 2014 20:24
Only issue would be a plugged radiator or a stuck thermostat.
Why do you think it has stopped flowing? Is the bike overheating?
"74 Yamaha DT 400 Enduro
- Dukesy
11 Sep 2014 22:28
Ive only just bought the bike recently. Got the carbies sorted out after a couple of sump fulls of fuel and just going over everything. The fan isnt working but ive found the problem and that's a pretty straight forward fix. Ive heard there has been some problems with impellers coming off. Shallow groove that holds the circlip. But would rather not take the exhausts off and pump cover to check.
- JR
12 Sep 2014 07:11 - 12 Sep 2014 07:11
You might find some useful info here
www.kz1300.com/
also
Last edit: 12 Sep 2014 07:11 by JR.
- Tyler
12 Sep 2014 18:34
With the fan running does your bike still overheat?
