Replacing Valve Seals
  • chconger
  • chconger's Avatar Topic Author
09 Sep 2014 07:36
#646822
Hi Guys
Looks like I smoke a bit on startup, so I am thinking on replacing the valve seals. Never been there before.
Can anyone point me to an article or video showing what this entails?
I assume cams come off and shim buckets.... then just pull out the seals?
Thanks
Chris
1977 KZ 1000-A
  • Tyler
  • Tyler's Avatar
Re: Replacing Valve Seals
09 Sep 2014 11:51
#646872
Um, no.
To remove the valve seals you have to take the valve springs and keepers off. Then you can pull off the old seal. The problem is that at this point there is nothing to hold the valves in place.
I have used compressed air to hold the valves closed when replacing valve seals in automotive work. Never done it on a bike engine but it should work the same, otherwise you have to remove the cylinder head to do the job.
You may be better off pulling the head anyway, if the seals have gone bad it may be time for a valve job too.
"74 Yamaha DT 400 Enduro
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
09 Sep 2014 12:04
#646874
Tyler wrote: Um, no.
+1
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
09 Sep 2014 12:08
#646876
I've used compressed air too to keep the valves from dropping on my 350 Chevy engine when replacing seals, but I've never done seals on my bike (yet). Ed
  • Dr. Gamma
  • Dr. Gamma's Avatar
09 Sep 2014 12:37
#646878
The factory Kawasaki service manual states that you must remove the cylinder head in order to replace the valve guide seals.
Now you wouldn't want to try something that your factory Kawasaki service manual doesn't have in it.
1986 RG500G 2 stroke terror.
09 Sep 2014 13:01
#646881
:laugh: :laugh: :laugh:
  • gbot9000
  • gbot9000's Avatar
09 Sep 2014 17:57
#646922
+1 on Service Manual ,no matter what you do.
This youtube video shows a guy changing the valve stem seals on a 1980 cb650 without taking off the head, using the rope trick.
I've wanted to try this ,but im still skeptical lol. I assume it is the same logic as when kz650ed used compressed air on his chevy engine to keep valves up?
79 kz650
  • chconger
09 Sep 2014 19:13
#646945
Thanks Guys
I think its an opportunity to pull the head and lap the valves. Winter project for sure.
Chris
1977 KZ 1000-A
