Oil-troubles
  • Piilgard
  • Piilgard's Avatar Topic Author
Oil-troubles
08 Sep 2014 15:03
#646736
Hi everyone,
Greetings from a first-season-rider from Denmark!
I recently got back from a trip in Europe with a friend. I drive a 1980 KZ650 and on the trip I ran into som oil-issues. I think I almost ran empty at some point, but i got her filled up again. On our way back the space beneath the carbs and behind the engine was covered in oil and so was my rear-tyre.
I havn't been able to find a new engine breather cover, as it has a crack in it. This happened due to my attempt to locate the oil-leak by tightening the cover-screw - way to go, butthead! You guys know where it might be leaking from? And where can I buy a new breather cover that fits?
Thank you in advance!
/Piilgard
I havn't been everywhere - but it's on my list!
Re: Oil-troubles
08 Sep 2014 16:22
#646743
Rendering Error in layout Message/Item: Kunena\Forum\Libraries\BBCode\KunenaBBCodeLibrary::renderEbayLayout(): Argument #1 ($ItemID) must be of type int, string given, called in /home/kzride5/public_html/libraries/kunena/src/BBCode/KunenaBBCode.php on line 314. Please enable debug mode for more information.
  • turboking
  • turboking's Avatar
Re: Oil-troubles
08 Sep 2014 16:39
#646745
You guys know where it might be leaking from? :unsure: :unsure:
sounds like you added too much oil........ :huh: if you over fill the oil level in the crankcase ,the excess oil will come out of the crank case vent.......or blow by from cylinder/ piston damage or low oil level damage. :blink: :S
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
Re: Oil-troubles
08 Sep 2014 17:11 - 08 Sep 2014 17:12
#646748
Does your bike have the stock air box and the L-shaped hose that connects the breather to the air box? Ed
Last edit: 08 Sep 2014 17:12 by 650ed.
  • Piilgard
Re: Oil-troubles
08 Sep 2014 22:07
#646794
No I replaced it with K&N pods, but have mounted a hose going up beneath the tank with some basic filtering inside.
It might be an overload. Hopefully..
Tanks for the link!
  • martin_csr
  • martin_csr's Avatar
Re: Oil-troubles
09 Sep 2014 04:41
#646803
Does your bike have the center stand? And how did you determine that the oil was low?
The normal procedure for checking the oil is to place the bike level on the center stand, engine off, give the oil some time to settle, then check the level at the oil gauge sight glass. Without a center stand or on an un-level surface, you could get an incorrect reading (too high or too low).
  • Piilgard
Re: Oil-troubles
10 Sep 2014 05:56
#646986
It started clicking very loudly when giving throttle - a very metallic sound. I left it over night and checked the oil-glass, which didn't have any oil in it, regardless how much I tipped it over. And when I filled her up, the noise went away :-)
