Will the KZ1000J motor Fit a 77 KZ1000 Standard
  • Kawinut
  • Kawinut's Avatar Topic Author
07 Sep 2014 11:37
#646586
I am looking to freshen up my 77 KZ1000B. I have been thinking about a new / used motor and was wondering if the KZ1000J motor was a straight swap. Years ago on the old KZR sight when I was a member I thought I remembered that there might be some modifications required.
Thank you, appreciate any insight.
  • StreetfighterKz
  • StreetfighterKz's Avatar
Re: Re:Will the KZ1000J motor Fit a 77 KZ1000 Standard
07 Sep 2014 12:13
#646587
The front engine mounts are different. I think the rears work but the fronts are a different design.
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
The following user(s) said Thank You: PLUMMEN
  • turboking
  • turboking's Avatar
Re: Will the KZ1000J motor Fit a 77 KZ1000 Standard
07 Sep 2014 13:06
#646590
hahn racecraft use to make a front mount conversion so you could use a J engine in a kz /z frame :S .....I don't think they make the kit any longer :blink: .... should not be hard to make one
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
  • Kawinut
08 Sep 2014 15:47
#646739
Thanks for the help guys, May have to venture out and try the swap, looks like I may need to shave the front tabs on mine, guess I won't know until I get it home, I thought there was some issue with the valve cover clearance on the frame?
