Bottom end of a 79' KZ650
- Nicj
06 Sep 2014 09:00
Hi all i am new to the whole KZ thing, as i am about to pick up a 1979 KZ650 B. It needs a hone job and some piston rings, but what i am not sure about is the bottom end. I turns over nicely, but should i pull it apart and rebuild that as well? From what i have heard, is that these bikes are pretty bullet proof so is there any reason to mess with it?
oh it also has 19,000 miles on it.
Re: Bottom end of a 79' KZ650
06 Sep 2014 09:43
A KZ650 with 19,000 miles is barely broken in. Just change the oil (use oil with the JASO-MA designation) and don't worry at all about the bottom end. Ed
- LineArtist
06 Sep 2014 11:29
Welcome Nicj. (everything 650ed just said)
My 79 runs great without engine work. Wondering what makes you think rings are necessary, is it a compression issue? If that good old bike has been sitting for years, chances are it needs to run and get oil to all areas, soaking gaskets and seals, freeing up rings, etc.
'79 KZ650B3 (stock)
'79 KZ650B3 (parts bike)
'06 HD 883R
'06 HD 883R
- kzoldschooler
06 Sep 2014 11:31 - 06 Sep 2014 11:34
I agree, bottom end on the KZ650 should be fine. FYI common issue after a rebuild or head gasket replacement if the gasket is too thick or does not seal correctly you will have low compression and very hard to start and less power etc....So you can determine if ok simply by doing a compression check (after running it enough to break in the rings)
That all being said why are you replacing the rings and honing it? If it is only 19K you should just run it as is. I just restored a 78 SR and used a KZ750E motor with 20K on it and it runs strong and great compression. No need to rebuild until after 50K miles or more!
Let the good times roll kzoldschooler
Last edit: 06 Sep 2014 11:34 by kzoldschooler. Reason: added info
06 Sep 2014 13:13kzoldschooler wrote: I agree, bottom end on the KZ650 should be fine. FYI common issue after a rebuild or head gasket replacement if the gasket is too thick or does not seal correctly you will have low compression and very hard to start and less power etc....So you can determine if ok simply by doing a compression check (after running it enough to break in the rings)
+1 My KZ650 has 57,000 miles without ever having had any engine work done, and some have gone double that or more without ever pulling the cylinder head. Ed
- steell
06 Sep 2014 17:56
Calling Ronkz650!!
I never can remember the numbers correctly, but I think he said 160,000 on one of his 650s.
Personally, I think his name should be "Cast Iron Butt Ron" :lol:
- baldy110
06 Sep 2014 18:09
I have over 150,000 on this one. I have rebuilt the top end not cause it needed it but because I wanted to install the 810cc kit in it. I have about 15,000 on the 810 kit. What makes you think the top end needs work?
- Nicj
07 Sep 2014 14:37
Sorry i didn't tell you this part. It needs rings and a hone job because i am buying it with the engine already torn half way apart. Lame i know. The top end is disassembled and there is some surface rust in the cylinders. I know everyone says stay away from the basket bikes but it is the only thing i could find in my area that wasn't over $1,500. The rest of the bike is in great shape though! Should i at least try and clean out the bottom end as good as I can? Thanks again for your replies.
- PLUMMEN
07 Sep 2014 16:09
If you don't know the history of the motor you have nothing to lose by pulling bottem end apart and checking everything out,like rod/main bearings and primary chain.
Theres probably a reason why the top end was torn down.
The following user(s) said Thank You: bluezbike
- Nicj
08 Sep 2014 07:28
Thats kind of what i have been thinking too Plummen. The other option would be to clean it out as best as i can without splitting the bottom end, has anyone done this? Or would it be a waste of time to do it that way?
- Grumpy Ole Artist
- Eschew Obfuscation!
08 Sep 2014 07:31
At least pull the oil pan and check for anything shiny/metallic in there.
1978 KZ650 B2
Former rides...1976 CB360T, 1985 Shadow 700, 1985 GPZ750Turbo
- baldy110
08 Sep 2014 10:02
With that info I would split the cases. You never kbow how the thing was stored with the top end off. Anything could hav egotten down into the bottom end.
The following user(s) said Thank You: PLUMMEN
