- Thank you received: 2
KZ 400 Engine Options
- Robwolf
- It's ugly, but it moves!
03 Sep 2014 19:38 #646178
by Robwolf
'79 Kz400H1 'cafe' and '94 En500 Vulcan in swampy Florida.
KZ 400 Engine Options was created by Robwolf
So I've given up on trying to get my engine back together. Unless I can get it to a good shop to get it back together and make sure everything is 100% for less than the cost of a working engine, I want to replace it. The question I have is what engines would fit the frame I have with no modification. The bike is a 1979 KZ 400 LTD. Double points if it will fit the carbs and exhaust! Otherwise I'll have to look at replacing them too. Honestly the bike does need new carbs anyways, but they do work.
- Nebr_Rex
- Thank you received: 300
03 Sep 2014 20:40 #646189
by Nebr_Rex
Expecting something for nothing?
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
Replied by Nebr_Rex on topic KZ 400 Engine Options
Robwolf wrote: So I've given up on trying to get my engine back together. Unless I can get it to a good shop to get it back together and make sure everything is 100% for less than the cost of a working engine, .
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- Robwolf
08 Sep 2014 18:19 - 08 Sep 2014 18:21 #646760
by Robwolf
Replied by Robwolf on topic KZ 400 Engine Options
Well I know I've got all the parts. I just can't do a lot of the labor, lack of appropriate tools is the number 1 reason for that. Also the lack of faith in my ability to not mess up the engine any further. I've already replaced the messed up rod bearings, just can't get the crank case back together and do all the work that should be done while the top end is off. I'm betting the labor cost for this is going to run more than a grand, which is why I'm looking at alternate engine options.
I found that the 440 engine will fit my frame and likely my exhaust as well, but I would probably need a new carb for it. Need a new one anyways since the adjustment screw on the left side of mine was shredded by the previous owner. Out of balance carb is probably one of the reasons my engine quit to begin with.
Last edit: 08 Sep 2014 18:21 by Robwolf.
