Where am I leaking?
  • bromz
  • bromz's Avatar Topic Author
  • 1981 kz1000 csr
Where am I leaking?
02 Sep 2014 15:56
#645996
This is just a general question. I am seeping oil from a few spots and it's gonna be a winter project. I think I can get away without a complete teardown. Here are a
Attachment ImageUploadedByTapatalk1409698609.685692.jpg not found
couple pics. Give your opinions
Attachment ImageUploadedByTapatalk1409698547.898188.jpg not found
Attachment ImageUploadedByTapatalk1409698574.668983.jpg not found
  • !Seymore
  • !Seymore's Avatar
  • Ride on...
Re: Where am I leaking?
02 Sep 2014 16:07 - 02 Sep 2014 16:10
#645997
Time to take some engine cleaner to it... GUNK, Simple Green or whatever you got... get ALL the junk outta there so you can see where, specifically, the oozing/leaks are starting.
Gotta start somewhere... and I'm not in IL to wash your bike 4ya! ;)
update: Although it does appear to be up in the valve cover gasket area, for starters... and oil does have gravity affecting its flow. Could have more areas seeping/leaking/oozing.
C.
79' KZ650-D2 [fsm] (Max)
83' KZ750-F1 LTD [clymers] (Kay)
82' KZ1100-D1 Specter (another project)
78' KZ650-B2a (J&H, A Project)
91' KZ1000-P (P = parts)
Last edit: 02 Sep 2014 16:10 by !Seymore.
  • nickleo373
  • nickleo373's Avatar
02 Sep 2014 16:56
#646012
It looks like a valve cover gasket, maybe a head gasket, and maybe the cam chain tensioner
1981 KZ550C LTD
"If you ain't first, you're last"
  • bromz
  • 1981 kz1000 csr
Re: Re:Where am I leaking?
04 Sep 2014 05:35
#646213
I see I am leaking in the upper left side of the engine. Could it be just a cam end plug? Also the oil that is on the fins on the left side could that be from the cam chain tensioner and also the oil switch leaking ?
  • weales
  • weales's Avatar
04 Sep 2014 18:33
#646286
Definitely agree with !seymore - give it a thorough degrease and dry off, then run the engine and you should be able to see where the leak/s are coming from.
Current Project
1968 Norton P11A Desert Sled
Other bike (and daily ride)
2004 Yamaha FZR 600
Previous Bikes
78 Z1-R (resto)
91 Zephyr 750
73 Mach IV (Resto)
78 Z1-R
78 Z1-R (stolen)
76 Z900
76 Z650
73 Mach IV
72 Mach III
  • bromz
  • 1981 kz1000 csr
07 Sep 2014 17:45
#646629
Well cleaned it a little fired her up and it is defiantly leaking from the chain tensioner. I think with the angle of the engine it runs into the fins then spreads as I go down the road. It an 81 csr 1000 any procedures for changing o rings and seals on the tensioner that aren't in the manual? Tips or tricks
07 Sep 2014 18:35
#646636
Check the gasket and replace if needed. Ed
